wilst checking my ht leads i have found a big chunk of the insulation around the ht terminal missing. not wanting this the become a problem i need to replace the coil. is there a hight out put coil that works on the 3b. i am thinking ahead here as i have plans to inprove things in the engine. how do you spec a coil and do i still need to use the pos or is there a all in one jobby. would this from 034 do the job
