Coolant hose puzzle
  • alg
    • Apr 2004
    • 1160
    Coolant hose puzzle
    I have a coolant leak.no surprise there. The leak originates from the short hose/thermostat front connection. You can see it leaking out.
    The puzzle is that the thermostat & hose no 8A0-121-109B were replaced in 2005 due to a leak.
    What I cannot understand is the routing. Looking at the car the hose from the bottom of the expansion tank joins the short thermostat-aux coolant pump hose as a T section. Its the no 30 & 39 on the F.A. where they do not seem to connect which may be the limitation of the diagram.
    Just to confuse me futher ABY photos show the short thermostat hose as a stand alone hose.
    Need someone who has BTDT
    Last edited by Fat Audi 80; 23 April 2008, 21:57. Reason: Reference to the Audi Microfiche removed.
    Alastair
    RS2
  • alg
    • Apr 2004
    • 1160
    And the F.A. image
    The F.A. image
    Last edited by Fat Audi 80; 23 April 2008, 21:57. Reason: Reference to the Audi Family Album removed
    Alastair
    RS2
    • Mikes2
      • 1704
      #39 goes to the radiator - nowhere near the thermostat area.
      Mike
      http://www.s2-audi.co.uk
      • alg
        • Apr 2004
        • 1160
        Thanks Mike. I have maybe solved it. Checked the RS2 workshop manual. Under cooling system modifications are listed three
        'Modified coolant pipe connection Fig 19-348/6 from coolant thermostat housing to heat exchanger,additional outlet for coolant expansion tank'
        'moulded part (seal) below coolant thermostat'
        'Drive gear for coolant pump,No. of teeth was 29 now 26'
        I cannot double check as the reference manual is engine 3B edition 01.91
        Looks like another RS2 oddity, can anyone confirm ?
        This would explain why that part no hose on the RS2 covers both 30&39 on the family album for a 1995 ADU
        Alastair
        RS2
        • Mikes2
          • 1704
          Must be the RS2 exception - no idea why they would make this modification.
          The pic above was my 1994 S2 which was a non-aircon model.
          Mike
          • s2avant
            • 2426
            The RS2 does have that strange hose setup. When Paul was sorting out the original samco coolant hose sets I sourced him one to use as a template.
            On the FA they use the same diagram though which makes it difficult to spot.
            Ben
            • alg
              • Apr 2004
              • 1160
              And having checked the leak again this morning it starts & continues after switching the car off. Its the turbo coolant hose leaking as the aux pump cycles coolant thru the turbo.
              Thats beyond me so off to the garage !!!!!!!!!
              Alastair
              RS2
