Hi all
Don't know much about this so excuse any daft Q's.
I know some of you use 1.9 bar wastegate springs, and I've even heard mention of 1.8 bar springs. What benefit do they have, if any?
I thought the wastegate was controlled by the ECU via the N75 not controlled mechanically. Is that right?
If there is a benefit to having a 1.8/1.9 bar spring, is it a straight swap and will it work with a homefries or does it require a remap or removal of the electronic wastegate control?
