Car: 1991 S2 3B
I've been trying to sort an overheating problem for the past couple of weeks now but have had no luck so far! The engine cools fine when traveling at speed (about 75-80 degrees) but it can get up to 110 when driving through town/traffic etc. Even when I leave the engine running idle the engine still overheats (the temp gauge sits at the second notch above 90 after about 20 minutes).
What I've done so far:-
- The aux rad was in a deteriorated state, so I decided to replace it with a decent second hand one. At the same time I thought it would also be a good idea to change the engine coolant.
- The top hose starts to get hot around the 70 degree mark, so I presume this means the thermostat is working ok?
- Both rads get hot and there are no cold spots - so I don’t think there are any blockages. This is also proven by the fact that the old coolant was clean when I drained it out the bottom hose (no signs of corrosion!).
Also, when the engine is overheating at idle speed the fan only seems to kick in every few minutes and only runs for about 12 seconds. This has no effect on the cooling system and the temp gauge remains at the second notch above 90. Does this sound normal? Surely the fan should stay on until the warning alarm turns off and the temp returns to normal operating levels?
Any advice will be much appreciated!
Thanks, Ste
Thanks, Ste
