how much does an s2 engine weigh?
  • WabTheKing
    • May 2004
    • 2567
    rough weight in kgs of an s2 engine please
    cheers
    will
  • spink
    • 4382
    about 180kgs with manifolds and turbo
    • 4WheelDrifter
      • Oct 2004
      • 5773
      • Country: Devon
      My engine minus the head is 110kg, I'll never forget lifting that on in.
      SS
      • Rusty
        • 18953
        Super Stu
        • 4WheelDrifter
          • Oct 2004
          • 5773
          • Country: Devon
          Just put the complete 3B head on the scales, that one's 30kg.
          SS
          • WabTheKing
            • May 2004
            • 2567
            cool my v8 is 194kg but sits bout 100mm further back
            • BRY
              • 3755
              Is 180kgs without any fluids?
              Is 194kgs with fluids?
              • WabTheKing
                • May 2004
                • 2567
                duno good queston tho
                • spink
                  • 4382
                  the oil in the sump would only weigh about 5kgs or so
                  • raymor
                    • Sep 2003
                    • 597
                    Is that 194KGs with PS pump etc.?
                    1997 A6 (C4)Q TDi http://forums.tdiclub.com/showthread.php?t=291269 - Sold
                    1987 CQ85RS
                    1994 S2 Avant- Gone
                    1991 V8 -Gone, but lives on in the TDi and CQ
                    Fintray Hillclimb - 33.20s
                    Doune Hillclimb - 55.02s
                    Forrestburn Hillclimb - 52.61
                    • raymor
                      • Sep 2003
                      • 597
                      Found this...
                      ... from here - http://www.gt40s.com/forum/gt40-tech...gine-info.html
                      The engine length you quote sounds like one of the newer cam chain engines fitted to the S4, the older units with the cam belt are a bit longer. The weight is about right as I measured mine at 180Kg without oil and water.
                      The approx sizes of the Audi ABZ V8 engine and gearbox are: -
                      Total length (Audi ABZ engine + 01X gearbox) = 1200mm
                      Length of engine (front pulley to bellhousing face) = 490mm
                      Length of 01X gearbox (bellhousing to rear casing) =710mm
                      Max width of engine (across exhaust manifolds) = 760mm
                      Max height of engine (sump to idle air valve) = 660mm
                      Drive shaft position (front pulley to drive flange) =690mm (or from gearbox rear casing = 510mm)
                      No need to bother with the dimensions and tape measure now Bry - I've just been out and done it. It should fit neatly
                      1987 CQ85RS
                      1994 S2 Avant- Gone
                      • BRY
                        • 3755
                        Check your e-mail.
                        • Acidburn
                          • 13459
                          Does everyone have one of these engines?
                          how much weight would it add to have the turbo's on the side of this? always wondered that after hearing/seeing the red american coupe that had this engine fitted (forum members name slips my mind) and what the weight penalty if any.
                          • raymor
                            • Sep 2003
                            • 597
                            Originally posted by BRY
                            Check your e-mail.
                            1987 CQ85RS
                            1994 S2 Avant- Gone
