fitting an oil pressure gauge?
  • MGaz
    • Feb 2008
    • 698
    where do i attach an oil pressure gauge to on this RE2500 engine?
    Oh, and also, since this engine went in, my oil temp gauge appeares to not be working, and neither is my water temp either.
    sorry to be a pain,
    but where are these located? There seems to be a lot of probes/sensor's in the block.. what ones are for what?
    cheers.
    TYPE-85 Coupe Quattro: clicky
    2.5L GTi engineering RE2500 190hp.180lb
    Schrick 272 cam
    C A C 2.5" T304 Exhaust
    ITG filter
  • terrybullwon
    • Mar 2006
    • 8782
    sorry to be a pain,
    cheers.
    The inlet side of the block is where you will find most of the sensors, also one just under the head at the rear of the block (this is your water sensor). 035 919 561 is the oil pressure sender i guess to fit there is a un-used thread that is most likey blanked off?
    Pug life (jay) can confurm this for sure
    Chef
    • MGaz
      • Feb 2008
      • 698
      cheers!
      cheersz!
      confirm,.. confirm! lol
      Schrick 272 cam
      ITG filter
