I've noticed on my S2 that when gently accelerating through the gears, I get a very slight hesitation when I'm on part throttle, usually between about 2200/3100rpm. I noticed the other morning on the way home from work, that when doing 70-75mph, I could feel the engine pulling, and then easing back and then pulling again, which is in the rev range stated above and still part throttle.
A run at WOT shows no problem what so ever, it boosts to 0.8/1.2 bar perfectly, this problem only seems to rear its head when the boost gauge shows vacuum or zero.
I've got a new WGFV and a new RS2 MAF, so they're probably pretty much ruled out, everything else is standard except for a Pipercross panel filter and a Milltek exhaust.
I found this thread using the search function, does it seem like the same thing?
Thanks,
Mark
Thanks,
Mark
just a case of replacing and hoping for the best.
