How long to reset ECU???
  • stiglet
    • Aug 2007
    • 1264
    Anyone know how long the battery needs to be disconnected for the ECU to reset?
    I know an all-nighter does the trick but i don't have that long!
    Just want to clear a few fault codes.
    Cheers.
  • DJones
    • Jun 2005
    • 2020
    Cheers.
    I only give mine a minute all sorted..
    • stiglet
      • Aug 2007
      • 1264
      Brilliant thanks mate!
      • Technogym
        • Dec 2004
        • 200
        • Country: Norway
        Will this be enough to have the ecu to clear the maf data? Having trouble with a S4 which has a very unstable idle and judders when giving throttle. Suspecting a faulty maf.... I understand that the ecu stores values from the maf, and this needs to be cleared from the ecu so that I can try to run the car with the maf disconnected...
        Any advise`??
        Vegard
