Annoying rattle from front of engine when cold
  • DarrenM
    • Aug 2007
    • 1227
    Last week or so have noticed an annoying "clack clack clack" from front of engine when cold. It lasts a few minutes,even when im driving off its still there, then dissapears when she's more up to temperature.
    I can't pin point exactly where its coming from but def sounds like top half and its right up front.
    Any ideas??
  • s2_bo
    • Oct 2005
    • 6067
    Is it maybe the tappets? Mine make a bit of a racket when cold too.
    91 S2 coupé - RIP
    98 S8 - Luxury barge
    • DarrenM
      • Aug 2007
      • 1227
      Nah, its def right up front not the usual 2 second tappett noise from start up,i had that on my old 2.0L 8valve coupe years ago.
      • PeteRR
        • 1326
        Sounds suspiciously like the hydraulic pump. But it's worth checking it's not something simple like a noisy or slack drive belt.
        • Lloyd
          • Apr 2006
          • 1559
          You might not believe this but it's possibly your aux belts. replace and/or tighten them slightly. Did the trick with my car 100%
          RS2+ (now sold...)
          • DarrenM
            • Aug 2007
            • 1227
            Yep, thats exactly the area its coming from,just sounds more like metal to metal. I'll try giving them a tweak later tho...cheers
            • Fat Audi 80
              • 10547
              Pour water over the belts just after you have started the car. If the noise goes way its one of the belts...
              The Perfectionist
                Spray a little WD40 on the PAS belt... bet it goes away
                New belt time if it does. BTDT
                • prosty
                  • Jun 2005
                  • 1114
                  could be that your timing belt cover is a little bent and scrapes against the pulley damper.
                  2004 9-5 aero
                  2009 Subaru Legacy Diesel
                  1994 Toyota Supra Eurospec 6-spd LHD
                  3-4 Audis in parts
                  • sal_s2
                    • 1288
                    I'm pretty sure it will be the PAS pump bearings, I've come across this a few times
                    • rs2jay
                      • Oct 2007
                      • 100
                      New PAS belt sorted the same symptoms on my RS2
                      • s2driveruk
                        • 12696
                        check the alternator bolts that mount it to the bracket, mine sounded like the pas pump until i realised the alternator was working itself loose.
                        1992 3b S2 Coupe
                        • DarrenM
                          • Aug 2007
                          • 1227
                          BINGO!! This seemed to be it, sprayed a bit of WD-40 on belt this morn and the clacking instantly went away. would never have thought it as in my experience belts normally sqeeeeal not clack clack clack
                          The voltmeter has been showing a flat charge of about 12v as well recently, after the WD it was on 14v charge again...quality! Can't believe it's the simplist of things, that never happens..will sort it properly when it stops raining, thanx for advice all
                            Told you
                            Took me 2 years to find that out!
                            • simesf
                              • Feb 2009
                              • 25
                              • Home: England Current: France
                              WD 40 did the trick for me as well - instantly!!! Hard to believe a metallic sounding noise like that could dissapear so quickly. New belt be next job!! Thanks.
