rotor arm question
  • denniselbows
    • 740
    rotor arm question
    evening all i have a question for you all . what is the idea of having a resistor in the rotor arm. i have just checked which rotor arm was fitted in my dizzy and have found the tip was loose so checked to see if there was continuity and have found a resistor. i need to get a new one as it is but just wondered why it's there.
    oh and what is the part no for the correct narrow tipe rotor
    never set your expectations to high that way you are never disapointed
  • LHD_Kid
    • May 2006
    • 3695
    052 905 414c is for the correct narrow rotor tip... (I believe there is also an option from Toyota, part number 19102-02020 , but have not tried it.)
    You can modify a wide one, grinding it down to the correct size....
    No idea about the resistor I'm afraid....
    HTH Chris
