RS2 injectors
  • urquattro-island
    • Mar 2006
    • 1915
    • Home: Norway Current: Iceland
    RS2 injectors
    how much are they worth?? one cap is broken, the orange one, at the end.
    japanischer industriabfall nein danke!!
    www.rackeltrim.se Icelandic Division
  • monstereddie
    • Dec 2007
    • 248
    The one from the RS2 are no longer available. The one you can buy now do NOT have the same specs like the other, even they look the same!! BE CAREFUL. Bosch has a "Repair Kit" so you can possibly fix them. Otherwise i would buy 5 newones or one used, that is much older than the one with the index from today.
    THE BLOG ABOUT THE REVENTON GREY RS2 called BOMBER....
    • Rusty
      • 18953
      I've been running with an injector without one of the plasic caps on for the last 2 years. Not as Audi or Bosch intended but not the end of the world...
      • urquattro-island
        • Mar 2006
        • 1915
        ok
        thanks guys, no these are out of an 1995 rs2. So they are the good ones, but i was thinking if i want to sell them, what can i expect to get for them.
        • monstereddie
          • Dec 2007
          • 248
          what do you want to use instead. you have to be clear about it, that yu need to map the injectors on your actual program.
          PS. Japanischer Industrieabfall? Nein Danke! is correct!! ;o)
          • Audi Parts Guru
            • 1317
            I would advise that you get them properly serviced before you sell them. That way you should get new pintle caps, o rings, filters and spacers fitted to each injector
