I've always been interested in the closed loop setup that the ford boys get offered for there cossie's to help with fuelling and economy, has anyone ever had anything like this fitted to an s2 or similar?
MSD Closed Loop perfect!
Installed the closed loop conversion from MSD and look at this CO readings!! With the old chip and greens it was set at 3.5% to let it pass the MOT. But only at a higher CO value it would run ok.
Now with this new chip and closed loop it runs like a dream all through the revs, very low CO at idle and a great fuel consumption!
Thanks a lot you guys from MSD!!
http://www.msdfuelinjection.com/mefi4.html
http://www.msdfuelinjection.com/blaster_efi.html
Thats the website for them, its quite an interesting idea and if it helps with economy then its a bonus.
