Engine concern...
  • europeanme
    • Oct 2005
    • 3817
    Engine concern...
    Well everything has been running OK for a while and after just passing my MOT I was looking forward to upgrading several items.....no such luck...
    having just been "pursued" by a standard yaris, it tried it's luck....when I gave it the usual foot to the floor it got to about 3500-4000 and started, what seemed like, missing....the whole car hesitated....tried it again after backing off....still the same...
    after turning off to a quieter road, and no poxy speed camera's on, tried it again...
    just the same now around 3000....a sinking feeling came over me....and the wife...how much this time?.....I love my car and don't be grudge it a penny but you know how it is
    The car has had the 1.8 coilpack conversion done....just had some other bits done at MRC so if anything was a-miss Doug would of seen it and sorted it....so it is something
    new....could it be the POS?...this is something I am still learning about...as is I5 mechanics.....or something as simple as needs new plugs etc.....
    guys-n-gals...any idea's??.....
    any advice is really appreciated....
    Mike
  • andyg plym
    • Nov 2006
    • 4646
    pos or coilpacks,sometimes they just let go other times intermitantly play up. had the same on mine. if its had the 1.8t coilpacks then there shouldnt be a pos fitted iirc.
    the 1.8t coilpacks are renowned for over heating and not lasting long.
    perhaps it could just be a mammouth air leak?
    I bet it idles fine? coilpacks dont tend to play up too much unless under load.
    any other symptoms?
    • A80Avant
      • Sep 2005
      • 10873
      • Country: Greece
      could be lots of different things.Does it seem to go on 4 cylinders?could be a coil pack.Usually harsh hesitation relates to them,when intermittent small cut like responce could be WGFV,lamdba,MAF,boost leak,etc...
      • A80Avant
        • Sep 2005
        • 10873
        • Country: Greece
        good thing i bought once the complete set of coilpacks from vagparts and replaced everything with OEM parts.Have heard so many bad things about the 1.8T and didnt go that route
        • europeanme
          • Oct 2005
          • 3817
          any other symptoms?
          it does idle fine......mammouth air leak you say.... would that not cause a problem all the time not just at the upper levels of accelerating??....
          got my boost gauge on order....
          • europeanme
            • Oct 2005
            • 3817
            it runs fine normally but only on 'give it some' it decides not to play ball....
            it's got an RS2 MAF on...and thats probably only 6 months to a year old....
            • UrS4Eben
              • Apr 2007
              • 128
              • Home: South Africa Current: United Kingdom
              sounds like what I have at the moment.... a failed coil will give you "vibration" type hessitation. Boost leak you will notice once the guage shows 1.2 bar and there is a lack of "vibration" wind your windows down and accelerate... You might hear a snake under the bonnet. I'm having my snake taken out on monday
              '92 UrS4 Avant
              www.olddubs.com
              www.expatsa.com
              • europeanme
                • Oct 2005
                • 3817
                gauge on order...see GB!!......should the coils on last so long?!?!?!....
                  Before you bail on the 1.8t coils, check to see if they are all snug down on the plugs. If they are installed correctly, they still down about 6 mm into the cam cover. Try removing one (a little twist and a stiff pull). Check the plug for tightness (22 lb ft - 30 Nm, tighten only). Then remove the rubber seal near the top of the 1.8t coil pack and then re-install the coil pack (temporarily). You should hear and feel the coil pack snap onto the plug. Measure the distance down to top of the coil pack and then remove. Add the rubber seal back to the 1.8t coil pack and reinstall, making sure that the coil pack is all the way down (based on your measurement). Repeat for the other four cylinders.
                  Then test again. If there are still problems, at least you will know its not a loose plug or coil pack.
                  Dave F.
                  • gedu
                    • Feb 2007
                    • 295
                    1.8T coils are notorious for breaking down in I5 engine.
                    All quattro products have been dermatologically tested, and are safe for daily use.
                    • A80Avant
                      • Sep 2005
                      • 10873
                      • Country: Greece
                      RS2 MAFs arent more robust than S2 MAFs.They tend to break down unexpectadly.But since it is quite new,i would check the coil connections as UrS4 says
                        Notorious? Exqueeze me? Back that up with data.
                        They do fail but no more frequently than a 1.8t. UNLESS you track the UrS.
                        Then the heat kills the little beggers.
                        Dave F.
                        • europeanme
                          • Oct 2005
                          • 3817
                          how long should coils last for??...the ones on mine where replaced just over a year ago....they should last longer, shouldn't they?!?!?....
                          • europeanme
                            • Oct 2005
                            • 3817
                            Dave F.
                            silly question time, Dave......if they haven't been touched, why should they have moved.... after been in the engine for this long then suddenly move sounds un-usual, does it not....
                            one thing I will say is the power output has been going 'downhill' for the last few weeks.....none of the usual "kick" in the back sensation...then I started to think I had a boost leak, hence buying the gauge....
                            could a "dodgy" plug lead to the same problem?.....
                            thanks for your help so far folks.....
                            Mike
                            • urquattro-island
                              • Mar 2006
                              • 1915
                              • Home: Norway Current: Iceland
                              i
                              can just tell you as a mechanic for audi and vw, we change alot of coils. They brake down ofte, i have ca 1000 coils to back that up...
                              japanischer industriabfall nein danke!!
                              www.rackeltrim.se Icelandic Division
