smoking dilemma
  • s2_southwest
    • Oct 2004
    • 823
    smoking dilemma
    Ive just got the car back after having a new head gasket and the head overhauled (new guides and stem seals etc etc) anyway, i thought the gasket was shot coz the car was smoking real bad. Smoking happened after i fitted:
    New turbo
    Oil catch tank and got rid of PCV system
    Its seems to happen just on idle so far, but then does sometimes smoke whilst driving. Question is do i have a badly re-conditioned turbo, or have i done something stupid when fitting the oil catch tank to make it smoke. Going to put some decent silkolene oil in tomorrow to see if that makes it better as ive got cheap ****** oil in at the mo. Really doing my head in so much that if someone wants to buy my car then its for sale.
    Pearl white 91-S2-3B K&N cone air filter - Home made induction pipe work - 18" RS4 replica alloys - Yokohama Parada Spec 2 rubber - Colour coded body work - Bilstein/H&R suspension - s/s 3in turbo back Longlife exhaust - SFS water hoses - Samco boost hoses - RS2 FARB - RS2 eyeballs - Squeaky interior trim & 2 bar!
  • pixsaudisex2
    • Sep 2004
    • 3110
    well you could always disconnect you breather system to see if it makes any difference but remember the breather doesnt want to be under pressure or it will smoke like a good un.. I made the mistake when i did my breather and i forgot to vent it ( instead of feeding it back into the inlet which would keep it at no pressure.)
    and dont sell it wait untilll fuel reaches about two pounds a litre.. and at least you can look back and say i used to once own one of them.
    • 220bhp
      • 2578
      • Home: United Kingdom
      To much oil will also cause this
      • andyg plym
        • Nov 2006
        • 4646
        what colour smoke?
        • s2_southwest
          • Oct 2004
          • 823
          sometimes black smoke sometimes blue. my catch tank last time i checked was vented to atmosphere so it shouldnt be under any pressure. i dont think its ****ed rings or else it would be blue smoke all the time. suspecting the new turbo....
          • andyg plym
            • Nov 2006
            • 4646
            who did the turbo?
            • s2_southwest
              • Oct 2004
              • 823
              turbocentreuk.co.uk
              • Acidburn
                • 13459
                I seem to recall a comment possibly by volcano_rs saying about the pipes going to the turbo, one of his had a bend/kink that was causing something like this, i've been having a look trying to find the link again.
                • Acidburn
                  • 13459
                  this any help? thats what i was trying to find
                  • andyg plym
                    • Nov 2006
                    • 4646
                    ive got a set of pipes spare in mint condition
                    • s2_southwest
                      • Oct 2004
                      • 823
                      http://www.s2forum.com/forum/showpos...&postcount=240
                      thanks for that acid, sounds interesting. the pipes are standard so i cant see why they would have a kink or restricted flow but i will have a good look, maybe there is a blockage somehwere. Thanks again, something to look at!
                      • DarrenM
                        • Aug 2007
                        • 1227
                        which pipes we talking about? I've been getting similar since new Turbo fitted, its only on tick-over from cold, drive and its fine tho and no other smoke when idleing when warm...
                        • s2_southwest
                          • Oct 2004
                          • 823
                          the 2 oil lines to the turbo, supply and return
