Dry sump kit
  • G60Rallye
    • Dec 2006
    • 1321
    Originally posted by Wizard-of-OD
    I would say it does...but good luck with your set up.
    Care to explain why?
    The pumps are going to create a near vacume in the sump and crankcase, so any oil is going to be sucked out by the pumps regardless of size.
    • gnutz2
      • Aug 2006
      • 928
      I would also be intrested why he thinks a smaller sump would be better.
      Like you say Hamish the sump will have vacum with the 2 scavenge pumps.
      @ Aelred Does this kit require a wider timing belt and cam pulley? in your pics the pullys look very wide.
      The ONLY S2 Golf!
      http://www.s2forum.com/forum/showthread.php?t=19402
      10.42@138mph
      https://m.youtube.com/watch?v=0wnkkOfFpXg
      • aelred
        • Jan 2005
        • 761
        Wider belt
        No it does not require the wider belt, the original one was made for a revving engine of above 8500rpm, just built for extra safety in mind. But if you are going to get the benefit of the drysump kit one of the many factors is the revving, which will give you the BHP
        Aelred
        • vcosmin
          • Apr 2008
          • 644
          • Country: Romania
          #49
          I was searching, for a dry sump kit, send a few emails, the prices semed quite big, for my income, on zatzy 4600E, was regarded as an OK price . But i have received an offer, from drysump.com, here it go :
          what i wrote. :
          Hi, I am intrested in purchasing a dry sump kit for Audi URS4 - Audi S4 in Europe, with 5 cylinder 2.2l turbo engine. I want to know if you have already a kit for this car, or if is posible to build one (3 scavenger + 1 pressure) , and what will be an estimate price, for the whole kit. Thanks
          Response :
          I would need to fab you a 5 cyl dry sump pan, but the rest of the components are no problem. Can you send me a stock pan? The complete kit, with tank, filters, pump, pan ( everything you need but lines) would be around $2000.00 .
          Which it seems quite good price ?
          • Azman
            • 3205
            That is a good price, depends on the quality of the parts though!!
            Dark Grey Avant
            RS2 FARB
            Alloy Subframe Bushes
            • aelred
              • Jan 2005
              • 761
              Originally posted by vcosmin
              Response :
              I am curious to know what exactly the kit consists of.
              Aelred
              • Jonnybravo
                • Aug 2008
                • 2051
                Good work on the kit, suprised it came out at being that expensive but thats development for you !
                I'm using a Swindon dry sump on my Escort, several other people I know use the Pace setups with good results, certainly a good modification if your going to start revving/tracking it.
                • Tommy200rs
                  • 285
                  #53
                  Comment to the kit list. Waudi Seat has the wide belt required if length is ok. Even the new pulleys only (down under, water pump, adj. cam pulley; - just for as RS upgrade without the glorious sump system)) would be great for the wider belt. (Check "Seat ETKA" for the wider Belt :-)
                  The Seat belt width is ok for wide adjustable cam pulley and then you only need the RS spec teeth number for water pump and the wide pulley at the bottom...
                  A dream sump machine for the power. aelred, Great Kit work .
                  [ Dahlbeck has the wide adjustable cam pulley alternative available. Now you know why it was meant to be wider for durability at 9k.
                  http://kmdtuning.com/index.php?_a=vi...&productId=679 ]
                    Was this a forum car this was fitted too? love to see the finished pics
                    • AustenW
                      • Nov 2009
                      • 8
                      #55
                      Nicely put together setup
                      • G60Rallye
                        • Dec 2006
                        • 1321
                        If you can wait a couple of months then my engine will be together by then with this dry sump set up fitted.
                        • QuattroFever
                          • May 2006
                          • 1360
                          bump. How did you get on with fitting?
                          Volcano ABY coupe
                          Ant
