Whats my options?
  • Graham
    • 1622
    Whats my options?
    Morning/evening, whatever it is over there. Yesterday my car developed a misfire under WOT load, i suspect the coils as they look well baked, and i am always reluctant to remove the cover as they look so fragile.
    So what is my options on replacement, my car is running about 280Hp (1.4 bar) and mechanically totally standard. The plugs have only done 1500 miles, so should be good.
  • Knight Rider S4
    • 3541
    I would go for the 1.8 coil conversion, save you allot of time looking for dud POS's and coils ..easy to install..........not everyones cup of tea I know as it takes away the coil cover away..but i think it is the best fix personally
    93 S2 Avant Parting
    91 URQ RR
    02 A4 tdi Avant
    • Graham
      • 1622
      I have been looking at the aan conversion on 034 efi and wonder if they will be alright with the chip i have in.
      Graham
        1.8T coils are not a fix - they are a workaround... Those parts are not specified as highly as the original S2 items. Sure they are cheaper but you get what you pay for... then you have to modify the cam cover to let some heat out in the hope they last longer. Personally I would just pay the extra and get some new originals.
        I'll also say that my misfires were cured *purely* with new HT boots on the coilpacks - I figured it was worth a try as mine were brittle and crumbly - and it transformed the car back to full health. Worth a try in my opinion if your boots look tired.
        Paul
        • Fat Audi 80
          • 10547
          Coilpack boots!
          See the groupbuy.......
          The Perfectionist
          • Graham
            • 1622
            My coilpack boots are only 1.5 year old, so i cant see it being them, they are still all flexy and rubbery. My old ones were like brittle teflon, they just shattered. I agree with you paul, the 1.8t coilpack is not a true solution, i was looking at the aan High output coils on 034, but they ruin the OEM look, i dont want any external coils. If i could do it with coils rated for the S2 (similar to OEM i mean) but delete te POS's then that would be for me the best fix.
            Graham
            • Bram
              • Aug 2006
              • 2582
              You can also buy one of these: http://cgi.ebay.de/ZUNDSPULE-AUDI-S4...QQcmdZViewItem
              • johne
                • Apr 2007
                • 1405
                Originally posted by bram
                These look similar/the same as the S2 OE replacement GSF parts sells for around £70 in the UK?
                • Rusty
                  • 18953
                  For a standard car like yours I'd go for OE coils but if you do go for the conversion then I'd fit 7A cam cover
                  • Graham
                    • 1622
                    Whats the difference between the 7a and aby cam ccover?
                    Graham
