rocker cover gasket part number check
  • vonbeck
    • 2455
    hi is this the correct part number for the above, aby coupe.And is there anything else worth changing while i`m doing this, ta very much
    034 198 025F
    also does anybody have the part number for the rear nearside wheel bearing? does this come in a kit and are there 2,ta
    ABY Cricket Green Pearl Coupe, blk leather
    THE ONLY TROUBLE WITH DOING NOTHING IS KNOWING WHEN YOUR FINISHED!!!
  • BrianSmith_S2
    • Jun 2005
    • 1342
    • Home: Northern Ireland Current: British Antarctic Territory
    Yep...thats the part number from the gasket kit i fitted to my ABY coupe
    Whilst i did mine i changed the plugs, and resprayed the air inlet pipe whilst it was off....and polished the cam cover
    • vonbeck
      • 2455
      cheers will probably do the plugs as a matter of course
      • Knight Rider S4
        • 3541
        Pictures
        93 S2 Avant Parting
        91 URQ RR
        02 A4 tdi Avant
        • Jas11n
          • 5067
          8A0 498 625 is your rear wheel bearing.
          Just the one on each corner at the rear, it's a quattro
          2001 Avus Silver B5 RS4.
          1995 S2 Coupe - sold (sniff)
          • vonbeck
            • 2455
            cheers mate good to have you back
