AAN vs ABY/ADU throttle body
  • A80Avant
    • Sep 2005
    • 10873
    • Country: Greece
    i would like to ask if there are any differences between those throttle bodies.From their codes i can find that the last letter is different (EF for AAN and EE for ABY/ADU)
    apart from possible throttle flap diameter,which may be different,can the throttle cable holder and the rev slower be the same?I know the potentiometer is the same,as it comes with the same part number...
    i just bought a AAN throttle body from the bay to use the parts as spares so...
  • lini
    • May 2007
    • 159
    • Country: Slovenia
    I mounted one on aby intake manifold and all fits together perfectly.
    S2+AAN in progress (again), BMW 3 compact
    • A80Avant
      • Sep 2005
      • 10873
      • Country: Greece
      Oh great then!
      • topsparky
        • Oct 2005
        • 2014
        only difference is the flange on the aan tb is slightly longer where the boost pipe fits on
        1. SHORT SHIFT KIT
        2. PORSCHE CAYENNE CALIPERS
        3. H & R SPRINGS
        4. BILSTEIN SHOXS
        5. NEW BUSHES AND HP2 STRUTS
        6. UPRATED HIGH OUTPUT COIL PACK
        7. ,3" turbo back s/s/ exhaust
        8. fmic fitted
