Lowish oil pressure 3B
  • drunkenalan20v
    • Feb 2005
    • 75
    ok gents help
    Cold start oil pressure is about 3 bar which drops to just under 1 bar when warm.
    I have tried both VDO electronic gauge and a capillary guage too, they both say the same thing
    the engine hasnt done more than 1000 miles and has only really been run occasionally but has done quite a bit of idling whilst getting a few things sorted.
    there is no leaks at all, the oil pipes look in good condition,
    where should i start looking?
    1982 UR Quattro with added 3B power!
  • aelred
    • Jan 2005
    • 761
    what is the most oil pressure when hot and lets say at 4-5k rpm? It is also dependent on what oil is used to some degree
    Aelred
    • drunkenalan20v
      • Feb 2005
      • 75
      when hot the max is around 3 bar, it used to be fine, up around the 5 bar from cold and upto 5 bar dependant on revs
      • DJones
        • Jun 2005
        • 2020
        Try changing the oil. Lots of idling and cold starts in particular may well have produced bore wash and diluted the oil with fuel making it thin hence low pressure.
        If not the cure its cheap to test..
        • drunkenalan20v
          • Feb 2005
          • 75
          going to drop the sump, see if the squirters are all present so ill probably change the too.
          • drunkenalan20v
            • Feb 2005
            • 75
            took the sump off, squirters as they should be, strainer nice and clean, removed the pump, took the cover of to check clearances in the pump, 11 thou, seems to much so will get a new pump, also checked all the bearings, crank bearing fine, some wear on the big ends including one bearing missing a large section of the white metal, so got some new ones on order too.
            300 quid for a pump from TPS!!! Jesus any suggestions
            • drunkenalan20v
              • Feb 2005
              • 75
              Bump
              • drunkenalan20v
                • Feb 2005
                • 75
                ok fitted the new pump, new big end bearings.
                its all back together, and the oil pressure is the same about 3 bar cold and under a bar once warm.
                its still low IMO
                HELP HELP HELP
                • re2500
                  • May 2007
                  • 2185
                  DId you check that the diameter of your crank pins were within tolerance? Do you have any blue smoke from the back end when driving?
                  "Difficult is worth doing"
                  • Acidburn
                    • 13459
                    its still low IMO
                    HELP HELP HELP
                    Could try get a cheap black faced gauge to just check it with, my 20v quattro sport has the problem someone had messed with it and turned the face of the gauge so it read wrong. They'd done the same with the battery one as well.
                    • AndyP
                      • 6049
                      Get a garage to plug a mechanical gauge into the where the pressure sender is, this will give you a much more accurate reading. Oh and oil pumps are only £150 from 034.
                      • 220bhp
                        • 2578
                        • Home: United Kingdom
                        I agree with andyP,its a simple way to check you real oil pressure
                        • drunkenalan20v
                          • Feb 2005
                          • 75
                          i have tried both capilary guage and a vdo electric guage, both in the same position both give the same results
                          • valjo
                            • 1110
                            • Country: Latvia
                            it is also possible that you have blocked oil lines or cooler.
                            Audi Coupe S2 1993
                            Audi V8 4.2 1993
                            Audi cabrio 1998
                            • drunkenalan20v
                              • Feb 2005
                              • 75
                              Nope All wrong!
                              changed the alloy filter housing and problem solved, upon examining the old one it seem that the valve inside was sticking, due to a fine grit like stuff clogging the piston like part which had a score along it, the grit wasnt present in the oil when it was drained and when the big end bearings were examined the looked tired but not scorred at all, the mains were all spot on!
