RS2 ECU Location
  • nothctap
    • Apr 2008
    • 68
    RS2 ECU Location
    Hi
    I need to remove my ecu, could someone give me a brief description of where its located in a lhd car and how to remove
    Many thanks
  • Wolfgang
    • Mar 2006
    • 250
    under or below the glove box on the passengers side in direction to the fire wall. i hope this has been understandable.
    wolfgang
    S2 Coupe ABY
    S2 Sedan
    S6 20V Avant
    www.audis2.de
      Yes - wolfgang is correct.. Its a bit of a PITA to remove if you are a 1st timer though... Search the forum for a 'how to' somewhere - same procedure on S2 and RS2 (3B, ABY, ADU)... NOT quite the same on S4/S6 (AAN).
      Paul
      • nothctap
        • Apr 2008
        • 68
        Cheers guys. I've located it and will remove this weekend
