Hi All
After a good fast run through one of our beautiful Mountain Passes in the Cape, my ABY S2 would not start.
Got the code 00515, so I bought the very expensive Hall Sender from my local Stealer.
But after replacement the S2 will still not start. Vagcom still gives 00515 fault.
We have checked the output of the Hall Sender and Crank postion Sender and they all give an acceptable pulse signal on a scope. Made sure the signal reachers the ecu as well.
However there is no signal to the coils or the injectors.
Any idea?
Any idea?
