engine setup, any suggestions?
  • lind4hl
    • Jul 2008
    • 2465
    hello, what do you think of my engine setup? any changes?
    new pistonrings
    new bearings etc.
    new rods (stronger, scat etc)
    intake from pogea
    intercooler from pogea
    ported head/ refirbished
    7a intage cam/ rs2 exhaustcam
    another exhaust manifold, (homemade)
    precision sc61 turbo
    org wastegate
    open airfilter
    bigger oilcooler
    titanium retainers
    harder valve springs
    better clutch
    VEMS aftermarket fuel/ignition system
    500bhp? possible?
  • A80Avant
    • 10873
    • Country: Greece
    why 7A intake and RS2 exhaust?you should have it the other way around.There will be more lag this way and none benefit on the high rev range!
    • lind4hl
      • Jul 2008
      • 2465
      hm okey, many that runs 7a inlet cam in sweden, but 7a exhaust and rs2 inlet?
      • A80Avant
        • 10873
        • Country: Greece
        the 7A exhaust will give you more power in higher revs,at least this is what most have done here that i have read about
        • lind4hl
          • Jul 2008
          • 2465
          okey, good then i will have 7a exhaust and rs2 intake, (who the hell needs power on low revs )
          do you think its 500bhp possible? ive heardthat you dont need to change the pistons befor 800bhp`?
          • vcosmin
            • Apr 2008
            • 644
            • Country: Romania
            I think that was more like 550-600hp, for pistons
            • gedu
              • Feb 2007
              • 295
              well, at least modified stock pistons can run for 700 range, but you really do need to modify them to lower compression. They are strong ones, but they do have their limits. You really have to think about fueling part, when shooting for that kind of power
              All quattro products have been dermatologically tested, and are safe for daily use.
              • lind4hl
                • Jul 2008
                • 2465
                fueling will be an pump in original case and tank, 8 or 10mm stainless steel fuellines fuellab fpr braided hoses with an fittings, 034 fuelrail aeromotive fuelfiter and so on.
