My sons 05 A3 2ltr T has started to run on 3 cylinders, anyone got any ideas as to what it could be. We came back from snetterton and it was fine,but after dropping me of he gave it some welly,got a puff of smoke and its missing a cylinder,he couldn't get the engine cover of to have a look,says it just wont come of. So we need a bit of help
A3 cover you have to pull off (WITH REASONABLE FORCE) as it is held in rubber grommets. Definately check the coilpack its a common problem and whilst your at it check the connector cables as they tend to become brittle with the heat.
