I've just cleaned my MAF and ISV (Idle stabilisation valve). While doing this I've come across a couple of problems:
On the MAF the turbo side screen was stretched and starting to tear away from the metal rim. As a precaution I've removed it to stop bits of screen taking a rollercoaster ride through the turbo.
As for the ISV. It was sticking open so I gave it a good blast with carb cleaner. This got it all shiny and clean but revealed a somewhat more concerning issue. The section of the valve which rotates to regulate air flow has a big lump on the edge of it. It looks as though someone has had a go at it with a screwdriver. This makes the valve stick in the closed position.
I took it out for a blast and it picks up much better now and feels a lot stronger on boost. The real issue is my idle speed is now around 700rpm (it bounces from 500-700rpm before settling on 700). Before it was around the 900-1000rpm mark. I assume that 700rpm is too low.
Is this going to be caused by the ISV or would an air leak cause it? I know the ISV controls the idle speed but is this only when there is a load on the electrics (headlights, AC, etc) or does it regulate idle speed at all times?
I can live with it for now (even I can't get an ISV on a bank holiday monday) but will there be any detrimental effects?
Ben
Ben
) At least it saves me getting the turbo repaired again!
