Your best bet would be to get some stainless braided hoses and suitable fittings to do the oil lines. You can always buy another length of hose if you do need to lengthen them in the future.
The neatest way to block the water lines would be to get a new core plug to replace the feed line, and just use a normal bolt (M14?) in the water manifold to block the return.
