Problemmo - Anybody know this one!
    This sounds like MAF fault or a big boost leak - check all the hoses thoroughly and make good.
    Clear the ECU faults before trying another drive. That fault code you have IS important... especially if it keeps coming back - the ECU is unhappy about something.
    • Bosscat
      • 95
      • Home: United Kingdom Current: Scotland
      Thanks Paul - will check all pipes - TPS ? - is this throttle potentiometer switch ????
      Excuse ignorance. The error code I get is 2341.
      Bosscat
      • 4WheelDrifter
        • Oct 2004
        • 5773
        • Country: Devon
        Echo the MAF here, I remember how mine struggled to run when I forgot to plug it back in once.
        Don't just check the hoses, test them properly.
        SS
        • s2_bo
          • Oct 2005
          • 6067
          Yeah thats what happened when my MAF died too.
          If you need a new one let me know, i have some in stock atm
          91 S2 coupé - RIP
          98 S8 - Luxury barge
          • Knight Rider S4
            • 3541
            I have a spare MAF here if you want to try and see if it makes a difference ..only doon the road fae ye
            Steve
            93 S2 Avant Parting
            91 URQ RR
            02 A4 tdi Avant
            • Heat Seeking Missile
              • Jul 2007
              • 658
              #21
              Sounds identical to how 20vcqdriver's ABY UrQ was running, I'd definately put my money on a ropey MAF sensor.
              Mark
              '93 Brilliant Blue Audi S2 Avant - Broken again.
              '98 Tahiti Blue Rover 216SE Coupe
              '96 Arktiksilber Metallic BMW 525td (E34)
              '01 Dark Green Jeep Grand Cherokee 3.1LTD
              '97 Polar White Vauxhall Vectra 2.0Di LS
              '96 Alpine White Peugeot 306 XLDt
              • Bosscat
                • 95
                #22
                Hi Steve - That would be great - saves me shelling out £150 for new MAF only to find its something else. think I have your moby No somewhere - will phone you.
                Regards
                Martin.
                • Knight Rider S4
                  • 3541
                  I am off tomorrow so I could pop it in for you if you are about
                  Steve
                  93 S2 Avant Parting
                  91 URQ RR
                  02 A4 tdi Avant
                  • Bosscat
                    • 95
                    #24
                    What are your movements - I get home about 6:00pm from Dundee where I work. Live just outside Scone on the Perth side.
                    Martin.
                    • Bosscat
                      • 95
                      #25
                      Temp sensor
                      Require temp sensor ( G42 I think ) sits on top of air manifold.
                      do you have one and how mutch.
                      Martin.
                      • Bosscat
                        • 95
                        #26
                        Problemmo - Update
                        Hi Guys - just like to confirm that all you people that figured that was a MAF problem were - CORRECT
                        Got MAF unit from steve - what a difference -
                        Have new one on order at Vagparts - still waiting for it to ARRIVE Not rapid are they !!!!!1
                        Thanks to all - for assistance.
                        Martin.
                        • Acidburn
                          • 13459
                          They normally if the don't have it in stock have to order it which takes a couple of days to come, surprised you did not have s2_bo's one he was selling before he went away.
