This is how she looks today.
And she has a problem. The engine starts niceley but after some time cca 20 seconds I get the idling problem. The RPM starts to drop an then almost dies and then picks up again. When the engine is hot it gets better but still not OK. VAGCOM says that i have a dead boost temperature sensor but that one shoul not efect the idling. The idle regulator does work too because when I disconect it it wants to die. I think there is enough fuel presure and as far as I know if I would conect fuel lines wrong way she wouldnt run at all. Spark plugs look ok. If anyone has an idea just shoot.
Thanks!
Thanks!
