vacum in fuel tank a4
  • nothctap
    • Apr 2008
    • 68
    Can any of you guys help a friend has got a 97 a4 1.8t sport
    But it seems like the the engine running is causing a vacum in the fuel tank
    So much so that it is sucking air through the cap.
    Any ideas???y
  • Flat on my back
    • Jan 2007
    • 2449
    Thinks there all spossed to do that...sounds more like the fuel cap has failed...try and borrow one to see.
    Carlos.
    • nothctap
      • Apr 2008
      • 68
      We've tried another fuel cap and it still does it, any more suggestions. Can anyone else confirm if it's normal?
      • Flat on my back
        • Jan 2007
        • 2449
        Excess fuel not required should be returned to the tank, might be a blocked/damaged return line or dodgy FPR...not too hot on the 1.8T's...sorry.
        Carlos.
        • Pirvu Eugen
          • Apr 2007
          • 1978
          • Country: Romania
          the valve from the carbon canister is blocked and there is no ventilation.
          i have managed to implode my steel tank in my coupe because off that.
          Hope this helps.
          • Pirvu Eugen
            • Apr 2007
            • 1978
            • Country: Romania
            the valve i tell you is inside the tank at a4..i think.
            • nothctap
              • Apr 2008
              • 68
              Thanks very much for your help, I'll let my friend know so that he can get it looked at!
              • nothctap
                • Apr 2008
                • 68
                I've had a look on the ETKA and can't figure out which valve it is. Do you happen to know a part number for this valve so I can reference it against the ETKA?
                Thanks
                • Pirvu Eugen
                  • Apr 2007
                  • 1978
                  • Country: Romania
                  What year?
                  In the picture..is the possition 34 or 28....you have to finda valve between the tank and the line till the carbon canister.
                  Hope this helps!
