Rod bearing directional installation?
    Just a quick question about the rod bearings
    When installint into the block is there a specific direction the aftermarket rods should be facing i.e the flywheel or pulley in relation to the bearing locater built into the rod?
  • mcandmar
    • Apr 2004
    • 5118
    They may require the tab to be on the leading edge of the bearing, i would look at a stock rod and make sure its the same way around
    91CQ20v - Gone to a new home
    93UR-S4 - The Magic Carpet
    94S2Bus - The Emerald Express
      Just need to know which way the tab should be facing i'e flywheel or pulley as it's simply case of reversing the rod before piston assembly.
      I haven't got a stock rod and piston assembly to compare as i'm building a complete seperate engine.
      • mcandmar
        • Apr 2004
        • 5118
        These might help, you can just see the tab for the upper shell, and from memory the tab for the lower shell is on the other side. You will need to double check the manual to see which side the two cast lumps on the stock rod should face, you should be able to work it out from there.
        • NoNonsense
          Forum Sponsor
          • Apr 2004
          • 673
          With aftermarket rods, such as Scats, the direction doesn't matter, just be consistent in every cylinder.
          Joe "NoNonsense"
          axis motorsport
          joe@axismotorsport.com
          • aelred
            • Jan 2005
            • 761
            rod direction
            That is right.
            Aelred
              Thanks folks, assumption is the mother of all f**kups so wanted to be sure.
