Poor Earth with 034 intake spacer ?
  • Eriksson
    • Jul 2004
    • 329
    I have some minor starting problems, have read that ground (earth) problems can be one thing.
    I have an intake spacer from 034 motorsport mounted could this cause it ?
    When cold it starts no problem. When hot i have to use a little throttle to get it running.
    Best Regards
    Audi S2 Coupe - 92
    Koni + H&R. PowerFlex bushes. 3" Exhaust
    RS2 IC. RS2 TURBO. RS2 EX MAINFOLD
    Best ET 2006 13.8 @ 157 Km/h (Stock turbo and EX mainfold)
    Best ET 2007 12.78 402m, 0-62mph: 4.2 sec, Speed: 175 km/h (GTEC)(1.1bar)
    Best ET 2007 201m 8.15@140km/h
    Best ET 2008 402m 12.34@177km/h
    My Project
    http://www.s2forum.com/forum/showthread.php?t=16997
    The spacer is an insultor so the IM can't be used as an earth as it will not conduct to the head.
    I have the same spacer and i'm planning to use some other points for earth as per S2_Bo's thread.
    • Rusty
      • 18953
      Just run a decent sized earth wire from the IM to the existing point on the cam cover.
        Well the question is what has Eriksson got earthed on the IM as the 034 / Wagner IM has no earth points on it!
        • ifa
          • Apr 2005
          • 57
          IM bolts conduct the electricity.
          • Flat on my back
            • Jan 2007
            • 2449
            Guys...
            Sounds like you have a 'hot' start problem...likey culprit is the thermal sensor at the back of the head.
            Get the codes pulled first, as a starting point.
            Carlos.
            • Rusty
              • 18953
              Unless you drill and tap it as per OEM
              • Eriksson
                • Jul 2004
                • 329
                Tanks for all the help. I will check with VAGCOM on friday,
                Now i have changed steer ball joints and topmounts (again)
                I will let you know my progress.
                Audi S2 Coupe - 92
                My Project
                • yodasfro
                  • Apr 2006
                  • 129
                  I have the spacer on my 200 20v and the grounds are in the stock location on the IM, no problems whatsoever.
                  Austin
                  1992 urs4 1991 200 20v avant 1990 90q 20v
                  • Jas11n
                    • 5067
                    Wouldn't the bolts holding the IM onto the head provide the earthing? Is the normal standard IM gasket made of non conductive material or is it metal?
                    Just trying to grasp the concept is all
                    2001 Avus Silver B5 RS4.
                    1995 S2 Coupe - sold (sniff)
                    • Eriksson
                      • Jul 2004
                      • 329
                      Thats right Jas11n. i thaut i would ask anyway.
                      I will check Codes tomorrow and se what pops up.
                      Best Regars Per Eriksson
                      Audi S2 Coupe - 92
                      My Project
                      • Rusty
                        • 18953
                        Indeed they should provide a pretty good earth but I suppose if you're worried then a separate wire is about 5 mins work and provides peace of mind
                        • Anagonda
                          • Aug 2005
                          • 70
                          Change the sensor at the back of the head. I had the same problem and the temperature sensor change fixed the problem.
                          • Rusty
                            • 18953
                            There are resistance graphs somewhere for the temperature sensors, SJM Auto or something like that?
                            • Eriksson
                              • Jul 2004
                              • 329
                              I have now replaced the engine temp sensor on the back of the head.
                              Same starting problems.
                              When hot i have to give a bit of throttle, otherwise i can crank for 10/15 seconds
                              before it starts.
                              i have new remap, 89mm MAF 550cc injektors.
                              Can it be someting with the injektors ?
                              Best regards Pelle
                              Audi S2 Coupe - 92
                              My Project
