Destroyed Thread!!!
  • Greenm3
    • Jul 2004
    • 512
    Destroyed Thread!!!
    Ive been replacing the turbo, and whilst taking the oil lines off i found that the turbo drain pipe going into the sump (3b aircon) has gone fubar. Ive had an anoying small oil leak for a while and smoking under the bonnet and i recon this is it.
    How do i repair it? Tap it out use a larger bolt, helicoil? im worried about how much metal I have to play with on the diameter.
    Or is it just cheaper to get the sump extension part? Considering how much a helicoil kit is!
    Please help need to get this sorted this weekend!
    Michael
  • s2driveruk
    • 12696
    sounds like it might be much less hassle to get the sump extension part....maybe someone on here has one lurking in their stash?
    1992 3b S2 Coupe
