Running problems
  • markrs2
    • 185
    Running problems
    Just rebuilt an RR engine for a UR and it starts and idles fine but will not rev. As soon as the idle switch opens the engine coughs and dies unless the MAF is disconnected. I have changes the MAF, Throttle pot, and ISV with no change to the symptoms. Checked for boost leaks and the system holds 1.5bar.
    ECU is holding no fault codes
    Any ideas?
  • 20Vcqdriver
    • 829
    similar
    Any ideas?
    Had similar problem with mine and it was the MAF. Have you checked all the wiring to/from the MAF. If it idles fine but then cuts out on opening throttle, it indicates the injectors and ignition are working fine. As soon as the throttle comes off the switch it starts looking at the MAF and all other sensors for its fuelling /timing. Is Lambda working OK?
    Strange no fault codes are coming up. Are you reading them whilst the engine is running?
    1986 Coupe q - 2281cc 3B, chargecooler, 2.75" exh & downpipe, ported head, water injection, CGR box, modified MD357 turbo, 440cc injectors, high power coil.
    2004 A4 2.5TDi convertible, re-mapped to 180bhp
    2011 A5 sportback 3TDi-Backbox delete, remap
    • quattronutter
      • Jan 2005
      • 690
      check all the earth leads too
      • markrs2
        • 185
        Changed the MAF and got the same problem. Have checked the MAF wiring as per the motronics manual and all seems fine.
        Not checked the lambda will change that today.
        [/QUOTE]Strange no fault codes are coming up. Are you reading them whilst the engine is running?[/QUOTE]
        Yes
        • markrs2
          • 185
          All earth to the engine are fine as are the earths from the ECU.
          • shark_90
            • 1475
            I have a similar problem with a mate's modded S3. Runs ok but misses a bit without the MAF connected, but with the MAF connected it doesn't want to run at all and spits fuel out the back.
            1994 Audi S2 Avant - in pieces
            2006 Skoda Octavia vRS 2.0TFSi - goes fast
            1985 Audi 90 quattro - is wet
            Don't forget the East Midlands Meet -Last Tuesday of every month at 7:30pm just off M1 J28!![/COLOR]
            • markrs2
              • 185
              Got to the bottom of this issue and it turned out that the MAP sensor was defective.
