problems with the ecu / boost
  • lind4hl
    • Jul 2008
    • 2465
    hi, my car is only rolling @ 0,7bar boost, i got these codes from the box:
    00519 - map sensor
    65535 - Internal Control Module Memory Error
    someone know how i can fix it ?
    or is the box crap so i just will buy Vems instead?
  • A80Avant
    • 10873
    • Country: Greece
    could be your map sensor in the ECU dead.Also the second code comes up sometimes if you are using generic chips.
    • lind4hl
      • Jul 2008
      • 2465
      can i only change the mapsensor in the box?
      • A80Avant
        • 10873
        • Country: Greece
        yes you can.although bosch 3 bar Kpa sensor is difficult to find anymore.Try ebay.de there a shop selling them
        • BRY
          • 3755
          Is it chipped?
          Have you got the standard chips to put back in?
            You might want to read this (and the link out to VMAP):
            http://forums.audiworld.com/s4s6/msgs/140335.phtml
            • lind4hl
              • Jul 2008
              • 2465
              it completely standard under the wintter i have built an 3" stainless exhaust and took out the carguard alarm that didnt work, thats all. (i took of the battery when i welded) and after the winter i tought it didnt go so good installed a boost gauge and only 0.7 bar boost
                When people with UrS4s have chronic low boost, I point them to the moisture trap (ususally there are no codes). Here is a post on how to find and fix the proble for a C4 UrS4. Your's will be similar, but different:
                http://forums.audiworld.com/s4s6/msgs/230668.phtml
