boost
  • akojacko
    • 107
    boost
    doug noticed your comments on hoping minhea can get the tubo boost to come in before 3500rpm ish . i feel the same thing but was told that due to size of the turbo's we have fitted that there is nothing we can do , its just the winding up time before hitting warp factor 9 . by the way your car sounds a peach wish i could make it to 30th 31st meet up but working both days if you do manage owt' let us know!!!. ps all this is a great forum site keep posting for all us novices....
    ako
  • Mihnea
    • 1288
    Hehehehehhhhh, calm down guys, if I tell you an RS2 turbo can spool before 3500 it means it can do it! full boost is usually obtained by 3000, in some cases below that, especially with non-ABY/3B cams (RS2 or 7A are good)
    Mihnea
    www.MRCTuning.com
    info@MRCTuning.com
    Workshop Directions
    • akojacko
      • 107
      hi mihnea , i found the right forum at last .lots of info on here and what seems to be a lot of very knowledgable enthusiasts.
      great...keep it up.
      ako
