error code 65535
  • Knight Rider S4
    • 3541
    error code 65535
    Having issues with the coupe and it is popping up with this code(has done this for the previous owner to)whats linked to it to, i think it is stopping me from opening the rest of the controllers on vag.com ..Is this possible..The only controller opening/reading is the engine ?..The problem is not the software or the cable as the i have tried it on another car and it works fine
    On a search here it indicates poor earthing or crap chips in the ECU
    Is there any other earths apart from the ones on the manifold i should look for ?
    Steve
    93 S2 Avant Parting
    91 URQ RR
    02 A4 tdi Avant
  • ericd
    • Nov 2003
    • 1240
    steve,
    without going into the 1's & 0's, it's an internal checksum validation quirk, can come from any chip that's been modified, nothelle, mtm, etc,etc, you got a standard chip set as far as you know, if so I'd been going down the earthing options.
    if reading the 65535 through vag-com , it'll show you whether you've got a standard chip at the header of the page where it outputs what it's found ...
    • spink
      • 4382
      Its a 3b isn't it?as far as i know the engine fault codes are all you can check on it,abs is not supported.Not sure about logging either.
      • Knight Rider S4
        • 3541
        The details from ECU is MOTOR PMC1...the guy i bought it off was on here link to what he had with it
        93 S2 Avant Parting
        91 URQ RR
        02 A4 tdi Avant
        • Knight Rider S4
          • 3541
          All the items that are mentioned in that thread are now fixed...apart from error code.new VR sorted the charge issue,the fuse/relay plate was screwed so changed the over,new lamdba
          Another code came up for air temp sensor fault (one on manifold i think)
          The car still has the issue were it is only boosting to 10psi so trying to work out if any of this is responsible as all the hoses are tight as f ,DV is working
          Have done output test and all is working as it should
          93 S2 Avant Parting
          91 URQ RR
          02 A4 tdi Avant
          • Knight Rider S4
            • 3541
            Well after a bit more investigation..I have found that there is a broken wire in the Air temp sensor which by the looks of it will be causing the lower boost figures as explained on SJM..http://www.sjmautotechnik.com/troubl...g/20vairt.html
            Have the ECU on my lap so going to strip it and finding out what has been done...Have checked all the earths and they are fine
            93 S2 Avant Parting
            91 URQ RR
            02 A4 tdi Avant
            • Knight Rider S4
              • 3541
              Well opened the ECU
              And have found there is only a 200kpa installed (standard)...The only thing that has been played with by the looks of it is the fueling chip?
              Thoughts gentleman?
              edit took covers off chips dark pics as flash covered off the numbers
              93 S2 Avant Parting
              91 URQ RR
              02 A4 tdi Avant
