Best coolant, suggestions pls
  • s2bug
    • Nov 2007
    • 484
    so you guys, to most a simple job...
    But as always I am sure there is a difficult and an easy way so advice please wold be great to draining properly and also as to what would be a recommended coolant to go in.
    Many thanks
    Julius
    S2 Avant ABY
    Use the official G12plus.
    Buy it from GSF or Audi
      Top tips for draining -
      1 - turn the heater to full so as to get most from whats in heater matrix.
      2 - open the expansion cap
      3 - undertray off
      4 - remove either of the two big hoses at bottom of radiator... The rearmost one is easier to get at... The clip for the other one can be in a right PITA location. If both clips unusable then remove the wiring to the big hex fitting at bottom of rad with the fan switches and tease that one out
      For refilling, loosen the bleed screw at top of main rad and run the engine - gradually adding water so as the expansion tank never runs dry until bubbles stop coming out of bleeder... Let the engine cool then top up expansion tank.
      A liter of coolant is plenty for UK usage - add more if you like but I wouldn't bother with more than 2 liters...
      • Ian Simmonds
        • Jun 2005
        • 2858
        Spot on.....
        93 MTMS2 Avant
        • shortsport
          • Dec 2006
          • 186
          Valvoline Maxlife it comes pre mixed so you have no hard water scaling problems
          For more than 35 years, Valvoline Instant Oil Change has provided oil changes and quick, convenient automotive preventive maintenance services for busy people.
          • s2bug
            • Nov 2007
            • 484
            Familys away for the W/E ! Heading to the garage for some 3b,TLC
            Thanks for the great info, will change forth with !!
            Anyone know more about Carsens bolt on IC for the 3B as all seems quiet on the front?
            Julius
            S2 Avant ABY
