mysterious engine problems
  • ridgeracer
    • 189
    • Country: Norway
    A friend of mine has bought a -94 UR S4 with an engine that will not exeed 2500rpm no matter what.
    The car has had a small water leak on to the ecu so this one is changed with a used but suposedly good one.
    The coilpacks are changed but the engine still behaves the same.
    It sounds like the turbo is spooling also, but once the engine hits 2500 rpm it starts to stutter and bang..
    Any ideas ???
    96 RS2
    94 urS4
    02 ALLROAD
  • volcano rs
    • Jun 2005
    • 2265
    Any ideas ???
    i had a similar problem once and it turned out to be a bent con rod
    • mdm
      • May 2007
      • 65
      if it's not reving then it tends to be to do with fuel, so check for air lecks, fuel pump, pressure etc it's usual something really simple.
        It sounds like the turbo is spooling also, but once the engine hits 2500 rpm it starts to stutter and bang.. Any ideas ???
        Assuming that the ignition is fine (and it might not be), it definitely could be fuel, i.e weak fuel pump, clogged fuel filter, etc.
        I would start with a fuel pump function test (and a clean filter):
        http://forums.audiworld.com/s4s6/msgs/89799.phtml
        If that test shows the fuel pump is fine, then I would move on to testing the ignition components:
        http://forums.audiworld.com/s4s6/msgs/115408.phtml
        HTH.
        • caterpillar
          • 2480
          have a audi 200 tqa: the fuelpump was gone; i have the pedal to the floor, and have only 51km/h....
          • ridgeracer
            • 189
            • Country: Norway
            But did it stutter and missfire on 2500 rpm even at standstill ?
            The car can do 2500 in 6. gear but not under any condition does it rew above 2500rpm.
            No oil smell or fuel smell.
            It idles fine..
            96 RS2
            94 urS4
            02 ALLROAD
            • caterpillar
              • 2480
              the fuelpump are gone i think... in tank pump ( borsch 040) or extern pump ( borsch 044)
