R2 Head onto 3B - does she go well sir!
  • s2bug
    • Nov 2007
    • 484
    Looking at Al`s Rs2 Head maybe to go stright onto my 3b.
    Views and benefits please as in fitting, is it worth doing, will I need other parts etc.
    Julius
    S2 Avant ABY
    Not just as simple as bolt-on... For one thing the RS2 inlet camshaft doesn't have a gear to drive your dissy - so you'll need to swap the Inlet cam for starters.
    Also worth knowing is that the higher lift exhaust cam from the RS2 may require remapping to cater for it properly.
    Valves are identical on S2 and RS2 heads - so are the port shapes - not worth doing unless you have a cracked or coked up head and need a quick swap.
    • terrybullwon
      • Mar 2006
      • 8782
      No gains , just hassel.
      Chef
      • s2bug
        • Nov 2007
        • 484
        That sorts that one out, Sorry Al.
        S2 Avant ABY
