ECU removal.
  • stevieyid
    • Apr 2005
    • 2251
    Thanks Paul. I just cant get it off and need, so annoying!
      Quick MP4 / 3GP video is self explanatory...
      • stevieyid
        • Apr 2005
        • 2251
        thanks Paul. I think i may have problem with mine then because when i pull that metal clip back it justdoes not release on the other side! Ill keep trying
          Bet you have a tywrap then that is stopping it moving.
          Or is the lever clip fouling on the metal bracket which surrounds the ECU ?
          • twoqu
            • Sep 2003
            • 3103
            #20
            The other end of the wiring connector is effectively hooked in, so you need to have it at almost a right angle to detach it. Be careful!
            • stevieyid
              • Apr 2005
              • 2251
              when u pull the lever hook up is that detaching the electrical connector? When the lever hook side is disconnected u can see the brown connector still connected and the wires going into the back of it!
                #22
                Up ?
                • twoqu
                  • Sep 2003
                  • 3103
                  #23
                  The metal lever prises the connector up but it does not release it completely as the other end is hooked in. You need to push the connector to a more vertical position. If you can't see I'll try and get some pics up to assist!
                  Oh and put the screws back in! They secure the two parts of the connector!
                  • stevieyid
                    • Apr 2005
                    • 2251
                    Yeah when i meant up its because i have the ecu out in the footwell. Pics would be great. The connector is still completely connected when u pull the lever
                      #25
                      You did watch the video didn't you ?
                      With the lever released, the connector pivots away from the side where the cables enter. Can't explain it any easier than the vid shows
                      • stevieyid
                        • Apr 2005
                        • 2251
                        yeah watched the video a few times but mine just wont come apart. Im wondering if the release mechanism is not working correctly
                        • stevieyid
                          • Apr 2005
                          • 2251
                          Paul when you pull the lever down is the connector underneath come out on that side? Because when i pull my lever down the connector is still 100% stuck in! On the side of the brown connector its looks like some old glue or something, has the black casing detached from the connector underneath?
                          • twoqu
                            • Sep 2003
                            • 3103
                            #28
                            First the corresponding slots in the ecu.
                            Second shows the prong on the connector.
                            Third the position when the clip is pulled back.
                            Fourth the angle needed to seperate connector from ecu.
                            • stevieyid
                              • Apr 2005
                              • 2251
                              I think judging by your pics the connector has come unstuck from the bit with the metal clip on.thats why i can unclip it
                              • twoqu
                                • Sep 2003
                                • 3103
                                #30
                                As I said earlier put the screws back in!
