hu uhave serch the ecu and got these error codes:
00519 and
65535
this means internal memory in the ecu and mapsensor (right english word?)
i have stock ecu and the problem is this:
0.7 bar boost.
really, really tired (ofcourse half the boost are gone)
ive heard that 65535 is a codet that ypu get when air temprature sensor in the intake is broken and is a common piece to fail?
and the result of when this sensor is broken:
reducing boost and set airtemp @ 40 degrees on the whole map,
kan the air sensor might be the one?
cheers, alex!
00519 and
65535
0.7 bar boost.
cheers, alex!
