Timing belt for stroker engine? And some general questions.
Hi, planning on building a stroker engine of a diesel engineblock and crankshaft, 158mm steel-rods and custom JE or CP pistons (any suggestions on measurements?).
What timingbelt do you guys use on your stroker engines?
Apparently you use a 3B water pump and an RS2 cambelt with the Tdi block. That's what I'm doing anyway, I have all the parts but havn't tried fitting them yet.
I am planning since long time ago the same? Are you going for 158mm 23mm Rods?
I also need measurements for the Pistons and of course pistons.
