Over reving the engine
  • Technogym
    • Dec 2004
    • 200
    • Country: Norway
    Hi folks!
    Last night i was flat out on 3rd and some how managed to put it in 2nd! (for the first time in 5 years...)
    Well result of this was a remarkable loss in power, and torque on low rpm. It also started to backfire with no throttle... Stopped the car after a feeling of heat in the engine bay. The Turbo and exhaust manifoild was pink!
    Thinking of this all night i am holding a button on broken valves... the backfire can be a result of the extreme overheating of the turbo...
    Any thoughts or similar expiriences??
    Vegard
  • DJones
    • Jun 2005
    • 2020
    Try doing a compression test on it, you may have caught the valves through valve bounce.
    Hope it helps and good luck.
    • quattro
      • Dec 2004
      • 768
      or the belt has jumped a tooth if it was a little loose.
      Probably the longet S2 project in history EVER!
      • Graham
        • 1622
        Here is a good video showing valve bounce
