Out of interest which systems have you used ? I'm just queing for the ferry after doing a course at Eurogas in Holland and they have given me some good advice and also offered to help sort a map with a LPG cut off to stop any issues with the valves etc.. Eurogas are the sister company to Landi Renzo who I assume you do know of.
We have now tested the latest Prins system with the electronic flashlube on a Range Rover Sport with good results, the system isn't as mappable as I would like which is why I am swinging towards the Eurogas system, the only issue being the noisy bulky MED injectors they would prefer I used over the Khein injectors.
ask me when you have any doubt, if I don't know the answer, well... I will search for it! yes please, let me know how's it going with the LPG setup!
