Whilst idling my S2 runs at about 90 degrees but whilst driving I'm seeing not much over 50 degrees.
Is this a common issue due to the twin rads or more likely to be thermostat related ?
I've not driven the car much yet but first impressions are its awful on fuel, definately running mega rich on boost which I suspect might be connected with the temperature issues ?
) and it should be better. If the coolant was up to temperature on the RR then it could explain the differences between running well on the rollers and slightly rich on the road.
and if you get over 25 then you have the patience of a saint!
