It will be with solid lifters but that work is extra, comes with rs2 head and some work already done dont know full details as yet ill post when i know more, the price seems pretty reasonable.
Have about <1mm more lift and approx 10 degrees duration per cam but inlet:exhaust ratio is similar. More than likely got a much larger lobe so you get a lot more overall...
Ok Thanks Andy for the info, the ones I have for sale are not the same Catcams that you refer to, so not similar to 7A cams.
I was just reading that link that you mentioned. Thanks for being so prompt.
Just as a note: I've measured two sets of 7A cams and they are only 212 on intake. Manuals are wrong stating opening 6 before TDC, should be 6 AFTER TDC making it 212 and not 224.
