Hope not to offend all audi fans, but i found a cheap supra engine, an i was thinking about swaping a supra engine mkiv, in a audi 100 C4 shell. I dont know if it fits in the engine bay, as supra has a 3l straight 6 (or evene 3.5l stroker) , but on 100 C4 is a 4.2 V8 ? so it should work ? There are some benefits, 1 extra pistont, 0.8l in plus, higher hp for less $$$ and high reliablity, and a full engine is only 1500-2000$
A V8 is only really the length of a normal 4 cylinder engine. I dont know how much longer the engine bay is in a C4 compared to an 80 B3/B4, but I know an in-line 5 cylinder is a very tight fit, no way would an in-line 6 fit in there. Shame really, its probably not a bad idea, they're tough as old boots them engines.
Mark
'93 Brilliant Blue Audi S2 Avant - Broken again.
'98 Tahiti Blue Rover 216SE Coupe
'96 Arktiksilber Metallic BMW 525td (E34)
'01 Dark Green Jeep Grand Cherokee 3.1LTD
'97 Polar White Vauxhall Vectra 2.0Di LS
'96 Alpine White Peugeot 306 XLDt
Yap, space seems tight, especially as the engine seems to be reeally in front of the car, but if i have the aproximative dimensions, and move the radiator, i think it might just fit, in. The E36, has no more space, but the engine placement, is more toward the cockpit, probably beacuse, of gearbox ?
