hi im needing some measurements, maybe someone can help me:
engine bore size in inches
crankshaft stroke in inches
rodlenght in inches
compression, 9.3?
intake side:
valve head diameter in inches
valve stem size in inches
camshaft valve lift in inches
duration @ .050
degreed centerline
lobe center angle
exhaust side
valve stem diameter
camshaft valve lift
duration @ .050
rodlenght in inches
compression, 9.3?
intake side:
duration @ .050
degreed centerline
lobe center angle
exhaust side
valve stem diameter
camshaft valve lift
duration @ .050
