Roose Motorsport Hoses
  • 3drGrot
    • Nov 2007
    • 30
    You have PM
    Regards Paul.
    • 3drGrot
      • Nov 2007
      • 30
      Prices are here.
      Regards Paul.
      • A80Avant
        • Sep 2005
        • 10873
        • Country: Greece
        #33
        paul you didnt say about the hose anything! i can send it to you...
        • 3drGrot
          • Nov 2007
          • 30
          Originally posted by A80Avant
          so there are the water hoses there now for the ADU as well.
          what are the prices?
          also what about that special hose i was mentioning to you,that only the RS2 has?
          Send me the hose and i will copy it for you.
          Then i can list both the ABY and ADU kits separately
          Regards Paul.
          • A80Avant
            • Sep 2005
            • 10873
            • Country: Greece
            #35
            ok,it has a small tear but i think you can manage with it.i will send it to you next week as it is in Greece and i will send it from there.
            cheers!
            vasilis
            • 3drGrot
              • Nov 2007
              • 30
              cheers!
              vasilis
              Hello Vasilis.
              It dosn't matter about a tear in the hose just as long as it is all there.
              You can get my address from my web site.
              Regards Paul.
              • A80Avant
                • Sep 2005
                • 10873
                • Country: Greece
                #37
                No problem! will do!
                cheers!
                vasilis
                • Big Lee M
                  • 2571
                  Does one of the ancillary hoses have the bled screw on it?
                  Just some finishing touches to do now
                  • martinjs
                    • 3205
                    Paul, do you have any plans to make a kit for the urs4/s6?
                    martin
                    • 3drGrot
                      • Nov 2007
                      • 30
                      No it dosn't.
                      Regards Paul.
                      • 3drGrot
                        • Nov 2007
                        • 30
                        martin
                        I don't have any plans for this car but if the demand was there then yes i would.
                        Regards Paul.
                        • Azman
                          • Sep 2005
                          • 3205
                          What hoses are in the middle set (i.e where do they go?).
                          7 Hoses,
                          1. Smallhose from Rad to water tank.
                          2. Small hose for side of block to water manifold.
                          3. From bottom of water tank to bottom of rad
                          4. From ARP to water pipe (one in the very middle small with bend in)
                          5. One from top of rad to aux rad
                          My brain is not placing the ones taht are left (long bent one in the middle and the one under number 2 in teh pic (really small straight one)
                          6.
                          7.
                          Also oil breather set. Is or has anything happend about this yet? Are you capable of doing a set for it that will withstand the battering it will get down there?
                          Only ask as feel mine is getting a bit blocked
                          Az
                          Dark Grey Avant
                          RS2 FARB
                          Alloy Subframe Bushes
                          • 3drGrot
                            • Nov 2007
                            • 30
                            7 Hoses,
                            6.
                            7.
                            Az
                            The ancillary hoses just contain water coolant.
                            I haven't done any breather hoses for the car.
                            When i recieve a set of OE breather hoses i will develope a set.
                            Regards Paul.
                            • Azman
                              • Sep 2005
                              • 3205
                              Cheers.
                              Dark Grey Avant
                              RS2 FARB
                              • MikeLarwood
                                • Aug 2008
                                • 278
                                If anyone can list the oil breather hoses for the car I'll donate mine...
                                Can vouch for the quality of these - they definately appear to be great!
                                Azman - as for where they go:
                                1. Very top hose (shortest) - hose next to the radiator/condensor from the block to the black pipe.
                                2. Underneath that - hose from the left hand side Heater Matrix (from the front of the car) to the black pipe bolted to gbox.
                                3. Far left - hose from top of main rad to the top of Aux rad.
                                4. Short 'U' piece - from After Run Pump to water pipe.
                                5. Under that - hose from right hand side Heater Matrix (from the front of the car) to the block (under brake reservoir).
                                6. Longest pipe - hose from bottom of header tank to bottom of main rad.
                                7. Bottom pipe - breather hose from top of main rad to top of header tank.
                                Next pair - top hose is the hose from the top of the main rad (towards rear of the car) to the stub under the inlet manifold and the after-run pump. Bottom one is from the stub at the front of the block to the bottom of the main rad with the connection to the aux rad (bottom).
