spark plugs for s2
  • Paulm
    • Dec 2003
    • 489
    Denso Iridium are no cheap replacement plug. They are what HKS use they get them re-named. HKS charge around £20 per plug but you can get them cheaper @ say £12 but they only say Denso. They are being used on cars with over 600bhp and running fine.
    IK 22 = heat range 7
    24 = 8
    27 = 9
    If you go to high you may well have probs starting on very cold mornings
    Looks like Bosch F5DP0R spark plugs for upto 400bhp then
    Paul
    S4 2.7 Twin Turbo, with a few mods
    • Beetie
      • Oct 2003
      • 1517
      Do the RS2's use the same plugs? If not are they a different heat range? I presume the ADU is the same as a ABY plug...
      • s2avant
        • 2426
        RS2 (ADU) uses the same plugs as ABY.
        Ben
        • Beetie
          • Oct 2003
          • 1517
          Ben
          Thought as much..
          • Albert
            • 1500
            • Country: Poland
            #20
            Originally posted by zlobo
            dut if you have 500hp wich spark plugs shuld you use then?
            I wold go with BOSCH - F3CS or BOSCH - F2CS
            AKmotorsport.net - Manufacturing Motorsport parts that do the job. | Audi S2 on Facebook | Best way of reaching me is sending email to albert@akmotorsport.net
            • akojacko
              • 107
              #21
              just whipped a plug out to see what is in mine with a mind to replace at imminent service. SPLIT FIRE TRIPLE PLATINUM TP392B. MADE IN USA..well never heard of those before and never used them . i was going to replace with the same . has anyone ever heard /used these plugs before??.thanks.
              ako
              • Keeper of The Kitten
                • Dec 2003
                • 2317
                I've heard of those American Split Fire plugs, being into the hot rodding scene!
                If I am right, these have a single ground electrode with a 'V' shaped cut and flared end, hence opening the ground tip up and giving the Split Fire plug it's name.
                Can't tell you much about the performance of them, except that somebody or other's independent report showed about 5% improved fuel economy?!! Supposed to offer a gap for flame propogation and a bigger spark "kernel" according to the blurb.
                Can't verify it, I'm using Bosch Platinum!
                __MDC__
                Martin Cutting
                • S2 Ant
                  • 3682
                  I use Bosch Platinum plugs too... got them for free so rude not to LOL
                  Ant
                  2011 Kawasaki Z1000
                  • akojacko
                    • 107
                    #24
                    __MDC__
                    you describe them bang on m8.any ideas where i could purchase these from as i am keen not to change makes unless i have to, and i have had no probs at all with these . cheers
                    ako
                      • Dec 2003
                      • 2317
                      Ako, I'll look for an advert in one of the mags and see if I can find a distributor for Splitfire!
                      __MDC__
                      Martin Cutting
                      • akojacko
                        • 107
                        #26
                        thanks KOTK...
                        ako
                        • audiman
                          • 4827
                          I was at a trade show a few weeks back and spoke to the NGK tech. dude about a different plug for the S2, he said to keep to the stock plug, if you make the wrong choice with a spark plug itcan cause a lot of damage. I have had to replace a set of valves in Ford Ka and a Renault Megane 16V this year, due to another garage fitting the wrong plugs. It caused the valves to burn out due to the extra heat!!! (Plugs were fitted at the dealers !!).
                          I would either use the stock BOSCH plug, or like myself use the NGK version. I have had no problems using these plugs for 30k miles. PFR7B. Platinum tipped plug for 20k change intervals.
                          Just my 0.02p HTH
                          Tom C - www.rcmr.co.uk
                          Audi UR Quattro
                          Audi 100 C3 2.0 5 cyl 115ps
                          Audi B5 RS4 645ps 911nm
                          • zlobo
                            • 967
                            Just my 0.02p HTH
                            my car wont run at the ngk plugs at all.. it mis fires al the time
                            ABT C5 Lord Of The Rings
                            2004 1/4 Mile ET 12.00 191Km/h @1,5Bar
                            2009 1/4 Mile ET 11.92 213Km/h @ 1,5Bar 437WHp
                            2010 1/4 Mile ET 11.45 110Km/h @ 1,5Bar 437Whp
                            kostic.nu
                            • VAG16VT
                              • Apr 2004
                              • 39
                              #29
                              I dont think these are made anymore,i could be wrong though,when they where released a good few years ago,they were super expensive plugs,and where all sorts of claims made by the company,claiming BHP increases and better fuel 100% better spark etc,there was a lot of hype on there release,but after all mags (CCC etc tested them) they were slated everywhere,so i woudnt bother using them again(even if you can get them)stick to the Bosch
                              • akojacko
                                • 107
                                #30
                                mmmmm. well , i might go for mihnea's recc' of bosch F5DPOR then. are these readily available??. cost ?? thanks
                                ako
