2.3 10v Non start when warm.
  • Beetie
    • Oct 2003
    • 1517
    Cant suss the thing out! Starts fine when cold or left for a while but when been on a run and the try to start it, it just cranks!
    Changed the plugs before this started and they are all ok. Changed the cap and rotor so thery are fine. Tryed another coil and that doesnt cure it.
    It will start with a push tho, although ******ed if im doing that every time!
    Any suggestions?
  • gedu
    • Feb 2007
    • 295
    Hrm, Does it have Hall-sensor in distributor? if has, sounds like that going
    All quattro products have been dermatologically tested, and are safe for daily use.
    • DJones
      • Jun 2005
      • 2020
      Is your battery/starter motor ok, push starting generally works better cuz the engine turns over faster push starting it than it does on the starter motor.
      Only a thought....
      • EspenW
        • Apr 2007
        • 1534
        • Country: Norway
        So the starter spins the engine? If not, starter heat soak could be the cause.
        Fuel vapor lock is another possibility, perhaps the fuel accumulator is bad.
        Coolant temp sensor could give wrong signal, fooling the ECU into thinking that the engine is cold, thus enriching the mixture too much
        1994 80E Avant
        1986 2L Golf 2 on Alcohol
        • Beetie
          • Oct 2003
          • 1517
          Was my thought and next port of call........
          Just found out the fuel pump is also playing up so might try one of them too.
          Thanks
